P500 Diagnostic code list?
Vondy
Vondy
1,613
10,732
Houston,OH
Any one have service manual for Pioneer 500 that can tell me what a code is for. Blinks 4 times normal and 1 fast (41? ) When it throws the engine light and code it wont shift, doesn't seem to even attempt to shift. Tends to do after its been running a while. Let it sit a while or overnight and it goes away. Seems to run fine and shift fine until the check engine light come on.
NTC/TAP Transition Member
11,888
90,656
Recall suggestions of doing a clutch adjustment as a first step with shifting issues. Have you seen this thread on shifting issues? Think someone had a gear position switch replaced. Good luck. P500 - Hesitant (paddle) shifting
Vondy
Vondy
1,613
10,732
Houston,OH
It shifts great until the engine light comes on, then it doesn't even attempt to shift. Once code is comes up, you don't here the shift motor even attempt to shift.
I'll can adjust clutch, just hate to cause it shifts so nice now. I was thinking maybe a sensor is going bad, position sensor, angle sensor, or ???? I'll see if dealer can tell me what the code means if no one has that info. Also considered battery, seems to be fine though 11-12 volts starting, then 14 volts running
It started doing this several weeks ago, just did oil change in case level was off and it was due anyway. No change since service.
Thanks
Vondy
Vondy
1,613
10,732
Houston,OH
@Neohio I saw you mentioned having a service manual, any chance you could tell me what the code is for?
68,435
41 is Gear position switch.
Upload 2019 8 13 17 30 22
21,765
93,379
Not sure if this will post in correct order.
But here you go!
Screenshot 20190813 173049
Screenshot 20190813 173058
Screenshot 20190813 173105
Screenshot 20190813 173115
Screenshot 20190813 173122
Vondy
Vondy
1,613
10,732
Houston,OH
Thanks guys!!!!!!
Kinda figured it would be a sensor. I'll start with replacing it.
Jackg
10
14
The DTC 41 indicates a problem in the gear position switch circuit. 41-1 indicates a short in the circuit while 41-2 indicates an open. Evidently, the third digit is read by the dealers DTC analyzer. This info is from the 2015-2016 service manual.
Reactions: Vondy and trigger
