P1000 DCT Oil Change
W
White Rabbit
24
54
Ione, Washington
I purchased filters for the DCT as well as the engine oil. Filters appear to be OEM parts, but did not come with O ring for filter cover. Depending on the condition of current O ring can I reuse? Or is this just a bad idea
DRZRon1
DRZRon1
1,438
4,395
technically you should replace if compromised
practically as long as its not torn and in good shape you can re-use
7,601
31,481
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Yes I have reused the o ring in the past, just take care when removing cover. Also DONT OVER TIGHTEN THE BOLTS!!!! no work wrench needed, just a 1/4" drive ratchet and hand snug. You can always snug it up more if there's a leak.
Also watch the spring in there.
DRZRon1
DRZRon1
1,438
4,395
what he said - I think there was a torque value error in manual maybe - don't make it a bad day
5,744
26,382
I've reused similar o-rings 'forever'. I've replaced the o-rings on my Talon once in 14k miles, only because I felt guilty. 🙃 Worst case, you end up with a small dribble of oil. I keep a spare pair ready to replace if necessary. Note that you'll dump ~2 cups of oil removing the cover.
Rayger143
Rayger143
3,312
28,896
Winfield, BC Canada
Hold the covers on with your hand and install bolts evenly or you will pinch the oring like I did. I keep them on hand in case I do it again.
1721692130317
tjoreo
tjoreo
1,032
1,992
Southern Idaho
For over 8k miles I reused the orings on both covers. Last fall I changed the oil before a hunting trip. After the change I saw that I had a small leak, so I had to come home and change the oring and mess with getting the right amout of oil added. I figured I would just change it every time from now on just for cheap insurance and less of a head ache. I believe alot of people are getting the oil change kits from Amazon and I think they come with the orings.
Reactions: Rayger143
5,744
26,382
The edge that the o-ring has to get past needs to be chamfered, it's a square, sharp corner and can snag the o-ring. Don't go nutz with the chamfer, the o-ring groove is cut very close to the edge, there isn't much room (depth) for a giant chamfer.
Rayger143
Rayger143
3,312
28,896
Winfield, BC Canada
Yes you’re bang on. I used a little emery cloth and it worked great.
Reactions: CID
