P1000 Custom Mirror Brackets Made for Honda OEM Soft Doors.
GROR
GROR
74
275
Castle Dale, Utah
ghostrocksoffroad.com
A-Pod HSD Multi-Pod & A-Pod Mirror Bracket: Custom-made for Honda OEM Soft Doors.​
FITS: 14-25 Honda Pioneer 1000-1000-5-1000-6
Our A-Pod Brackets are made specifically for the Honda OEM soft doors. We have two bracket configurations available: the A-pod HSD (Honda Soft Door) Multi-pod that will also mount a 50-54’’ lightbar, and the A-Pod HSD mirror-only bracket. Both models have a 10mm bolt hole, and we provide a 10 mm-8 mm reducer so that the brackets will work with various 10 mm and 8mm single-bolt mirrors. When we tested mirrors, we found that the tusk mirrors worked the best. However, we only tested the Seizmik Embark and never tested the Seizmik Pursuit or Strike UTV Side View Mirror.
Testing included running the mirror into trees at various speeds, which was nothing extreme, but if you wondered why the brackets are made from 1/4'' steel, there's a reason. The A-Pod Brackets' Solid steel construction is designed to withstand the most extreme punishment, allowing the mirror to fold in when hit and return to its original position in one move.
Available at - www.ghostrocksoffroad.com
20231002 082702
Paul Canning P1K mirror a pod
20230924 102023
Web site photo mirror folded
Website photo 1
Wisco pioneer
Wisco pioneer
45
205
Do you just drill holes into the plastic to mount the bracket
JNo323
JNo323
183
1,121
Middle, TN
@GROR, has anyone tried these on a Talon with OEM soft doors?
JNo323
JNo323
183
1,121
Middle, TN
Spacing on Talon is 1-1/8”. Thanks for details.
Reactions: ChadD
GROR
GROR
74
275
Castle Dale, Utah
I just finished installing the New lighted mirrors from Tusk. ill get a chance to use them Lion hunting in the morning. The mirrors are currently on sale. Visibility is great.
Pro Dpn1PYOQ
Pro 0kwy3GyS
Pro beAHWXA1
A POD HSD
Reactions: TripleB
211,812
Anyone know of a mirror and bracket that has the hinge / breakaway behind the A pillar?
