Club store Aux Switch Fuse size
CJQuig
CJQuig
79
215
St Johns, Nl, Canada
what size fuse goes on the club stores AUX/off/key-on harness? On the “to battery” wire.
Edit, perhaps the "diode" may not be working after I overloaded the harness. I obv have no idea, may need new harness...
Reactions: ChadD
68,192
2 amp.
More info please.
Is the switch lighting up? Both up and down?
Is the stinger working in either mode?
Reactions: ChadD and CID
CJQuig
CJQuig
79
215
2 amp.
More info please.
No lights, The switch can't get constant power from 12V, fuse is blown, I cannot find the original fuse. Stinger is new.
Reactions: ChadD
68,192
When down, power comes from a key-on source (yellow wire). key-on should be lit. Unrelated to the fuse.
When up, power comes from the second battery. Fused; You can use a 5 amp fuse. Only AUX should be lit.
Reactions: Coeus and ChadD
68,192
IDK...
I find it very odd to have both circuits messed up.
Hook up Recap.
The big hoop goes to the top post, battery side of the stinger.
Both small loops, go to the small post of the stinger. Doesnt matter which one.
The green wire needs a ground.
The yellow wire needs a key-on source. (Or other 12v to test)
And that's it.
I personally test these. but, I make no claim of perfection. lol
Let me know what we need to do to get you fixed up.
