Cheap back up lights/work lights
rallymachine
9
0
0
So I finally installed some back up lights for plowing my road and drive way. Parts for build, I used napa par 36 4" work lights $12.50 each. Fog light relay harness kit with switch $26. Four feet of wire loom. Two butt connectors. I think they work great. No volt meter to test load yet.
IMG 12361
IMG 12351
IMG 12341
IMG 12331
IMG 12311
68,387
Looks good. Did you wire them to come on when in reverse?
rallymachine
9
0
0
Not yet. I'm looking into that next.
68,387
You can tap the gear shift sensor wires near the right rear tire. There you will find a wire that will GROUND when in reverse. You could use that for a relay.
I'll try to get pictures tomorrow or Tuesday of the location.
bellmichael8683
0
US
Questions : (1)What gauge wire? (2) relay part number?
Sent from my SAMSUNG-SM-T337A using Tapatalk
Ratchetdan
Ratchetdan
29
26
Alaska
@Hondasxs, did you ever find the wire to tap into? I'm interested in tapping my rear LEDs into it.
