Broken rear shock. What to replace with?
PhilCod
PhilCod
364
759
Indiana
Drive side rear shock broke. I have 6,300 + miles of hard butt whipping rocky trail riding on her, so no real surprise. I do not have a live valve, and I did modify my shocks with Bandit tender springs, and Schmidty Racing caps with schrader valves so I could adjust inflation. I'm thinking I should just replace the rear shocks all together. I am thinking about Elka. I had a set of those on a Rincon, and they were fantastic. But if someone has replace the rears with something else, please let me know your input.
IMG 4368
211,433
I've never thought about running different brands front and rear, so I would base my decision on both front and rear even if you just buy the rears for now.
Reactions: BrianN and Smittyp
DRZRon1
DRZRon1
1,408
4,343
U can always have it repaired if that’s a thought, any descent shock shop can turn that around with minimal fanfare.
Almost seems like something else is wrong to have the springs rub like that. Just an fyi - the nitrogen just keeps the oil from cavitating.
Hometeam
Hometeam
1,040
4,389
Normal, IL
I have a buddy running the stage 5 Elkas on his X and is really happy with them. But I also think Bandit makes a set for the X that are pretty nice and less money than the Elkas.
5,736
26,291
@JWB recently put a full set of Bandit shocks on his X2 for ~$2400 and is very happy with them.
SLOWPOKE693
SLOWPOKE693
2,005
7,777
Somewhere in Texas
Cheap springs bow, it's just the way it is. Run quality springs like Eibach, Hypercoil or Swift and bowing and rubbing will never be a problem.
SLOWPOKE693
SLOWPOKE693
2,005
7,777
Somewhere in Texas
I would personally send the shocks to a competent shock tuner to get the broken one fixed and then have the set revalved and resprung for your machine and riding style. It's going to be the most cost effective way to get your shock fixed and get the ride tuned up all at the same time.
PhilCod
PhilCod
364
759
Indiana
The rubbing is due to the shock being broken in 2 and the loose piece rubbing against the spring. I guess I could buy the parts from Fox to fix it. I'll look into that.
Thanks, now that you and Ron have both said that, I will look at that option. I do have Bandit tender springs on the front and the back, but it may be time just to send them both out. I did break one of the Bandit springs on the front. They replaced both free of charge. So I may look at what they have to offer.
DRZRon1
DRZRon1
1,408
4,343
Jeez - something just seems to be wrong with the setup of the shocks or you are a madman pounding that machine.
Broken shocks, springs, etc… nothing against bandit but I put all 4 of their tenders on my 2X day 1 - and that lasted about 50 miles since they didn’t do much of anything except take my time swapping springs - ended up biting the bullet and got FCR to respring and revalve all 4
the slowpoke man knows his stuff - good quality components go a long way !!!!!
Good luck getting them fixed up and let us know what you end up with .
ScottJ24
ScottJ24
78
223
Cresson, TX
You WILL NOT be sorry having the shocks revalved and resprung!!! I had mine done and it now rides great.
PhilCod
PhilCod
364
759
Indiana
Jeez - something just seems to be wrong with the setup of the shocks - They lasted 6,100 miles
or you are a madman pounding that machine. Yes I think this is the issue.
I put the Bandits on and also re-valved the shock at the same time, so I think I had a different experience. I went with TerryH's set up.
the slowpoke man knows his stuff - good quality components go a long way !!!!! Absolutely agree. He has helped me with a lot of set up stuff.
Reactions: Hometeam
