P1000 Bed extender
kandt
kandt
126
762
Bluegrass state
I bought the seizmik bed extender back when I first put a deposit down for a 21 model. (At the time saved about $100 by going ahead and ordering it) Year later ended up with a 22 PK5 and it fit great on mine. Use it all the time for extra bed space.
3B925E72 83C9 42C0 A370 9A61FFC02697 3DBB7EB5 35C2 4D31 BB6A A49C8C18E63B
Bandman
Bandman
132
463
Hayden Lake, ID
That’s weird! All I’ve heard is that it won’t fit on a 2022 Including from the factory. I would really prefer the siezmik except for the price.
kandt
kandt
126
762
Bluegrass state
The only thing I have a problem with it is using my bed mat, the sides of the extender fit really snug due to the lip of the bed mat when I close the tailgate.
Mounted up just like other model years.
SSToddS
6
44
Sand Springs Oklahoma
Just purchased and installed the Kemimoto bed extender. And while it folds down you still cant shut the tailgate and have the seats up. During install you have to remove the tailgate briefly. The instructions suck but if you remove the inner rear panel on the driver side you can slide the rear out enough to remove the tailgate. PIA to install but works and looks great. Mine is a 2022
Pondbed
Garage bed
Bandman
Bandman
132
463
Hayden Lake, ID
Just purchased and installed the Kemimoto bed extender. And while it folds down you still cant shut the tailgate and have the seats up. During install you have to remove the tailgate briefly. The instructions suck but if you remove the inner rear panel on the driver side you can slide the rear out enough to remove the tailgate. PIA to install but works and looks great. Mine is a 2022 View attachment 367741View attachment 367742
Thanks for the pics and info!
Jankyeye
Jankyeye
882
4,182
Tampa, Fl.
Finally got around to installing the Rough Country bed extender. Overall I think I’ll be happy with it. The directions were a bit vague in some areas and the hardware call outs were not 100% correct but I got it figured out.
E9A00FBA 554C 44FC 9A0A 862B6919641E 27E44206 55D0 433B A494 2AD96C6CB8B5 B5FE81AC 0A04 4912 BECF ED74691952D7 352BEC30 37CE 454D AAA0 2FDB112F95F8 2F1EC9F8 0ADF 426A 98CF B25FCF39C325
Jankyeye
Jankyeye
882
4,182
Tampa, Fl.
Works well folded & unfolded with the rear seats up and down. There will likely be some rattles as mentioned before, but only with the tailgate closed. mainly due to the the cable extender design.
The cables themselves don’t hold any weight with the extender side rails locked in place. The sides lock into the factory cable bolts which makes the cable extension bracket/bar a little floppy with the tailgate closed
87325E52 7528 4E4C 854E C00FEA8C93B1 8CC79D0D 1440 4B3A B6EA BE55B1BD5D35
Bandman
Bandman
132
463
Hayden Lake, ID
View attachment 368082 View attachment 368083
Thank you!
tdhanses
tdhanses
1,044
3,553
Kansas
It’s probably because they haven’t tested it on a 22 yet, so won’t say it’ll fit, I bet it gets updated to fit at some point by them.
Reactions: Bandman
JLR
JLR
30
65
Maine
View attachment 368077 View attachment 368078 View attachment 368079 View attachment 368080 View attachment 368081
Thanks for the detailed photos and review. I think this will fit my needs well with a nice compact design so I have pulled the trigger and ordered one!
Jankyeye
Jankyeye
882
4,182
Tampa, Fl.
Install tips, you only need to remove the plastic from the bed on the drivers side, the first brackets attached to the tail gate have some wiggle room, make sure the tail gate closes, if not loosen them a bit and adjust to clear the bed. Also, the flange nuts go to the bolts for the clamp brackets (first 8x25 bolts used). And lastly, the tailgate cable uses the stock hardware and the new bolt, washers, etc go on the very bottom where it attaches to the new bracket.
czajkaej
czajkaej
Ridgecrest, CA
For those that got the Kemimoto bed extender, you can fold it up and use the rear seats if you make some modifications. Personally, I was not happy about the amount of modifications and cursing required to achieve the desired effect. In hindsight, after seeing the Rough County variant of similar cost and what appears to be a design that would fold up as desired, I would have gone with that one.
Bandman
Bandman
132
463
Hayden Lake, ID
i emailed Siezmik asking if their bed extender would fit a 2022 1000/5 and they said ‘it should fit just fine!’. Has anyone else heard this?
Robobrainiac
Robobrainiac
2,677
9,295
@sdelam
@Seadonist
Do you think a tailgate stiffener will work with the rough country bed extender?
How easily is the extender removed if I choose to only use it on trails and store it at home?
Seadonist
Seadonist
380
1,117
New Orleans
I’ll have to take a look at it when I get home and get back to you
Reactions: Robobrainiac
