P500 Battery/cold weather starting?
HiFive
HiFive
710
2,961
West Central Fl.
p5 would only turn over and sputter occasionally when temp was 29 degrees, but later temp was 45 degrees started right up and voltmeter showed normal charging numbers. Any ideas on why p5 would not start?
HUCK
HUCK
1,047
2,319
ARIZONA
It was cold ?
Reactions: Red500 and HiFive
Dave75
Dave75
123
500
How old is the battery?
What is the battery voltage at 29F before starting.
I know this is not the same problem.
My truck would not start at -11F, but would start at 26F.
Had to charge the battery to start at -11F.
The battery was over 3 years old.
Changed the battery and fixed the problem.
Reactions: HiFive
Hillbillytnt
Hillbillytnt
558
2,051
Ky
What was your meter reading before you hit the starter ? My 1k is seeing some low numbers on these cold mornings 11.5 1st reading dipping to 9.5 when cranking. But then she hits and everything goes up.
Reactions: HiFive
HiFive
HiFive
710
2,961
West Central Fl.
Battery is going on 5 yrs. Going to check it out. Thanks for the input. Voltage was a little low 11.9 but jumped to 12.5 after it started and I shut it off.
JMynes
JMynes
553
3,267
Augusta, Maine
11.9v is a bad battery, but it might not have been fully charged. Charge the battery fully with a good quality ‘smart’ battery charger. Disconnect the charger after it’s full. Let the battery rest for an hour, with no load on it. Then check voltage. In cold weather a reading less than 12.5v would prompt me to plan on replacing it.
In warm weather a brand new fully charged 12v battery should be close to 13v at rest (no load, 1 hr after removing the charger).
Reactions: Dave75 and HiFive
Scoop
Scoop
5,325
20,985
  3. Talon R LV
It was cold ?
Well, that depends on if you think 29F and 45F are cold ... 😆
@HiFive - All signs and symptoms seem to point to it being battery replacement time.
HiFive
HiFive
710
2,961
West Central Fl.
Yep just purchased a replacement battery today. Dealer has heard there may be a battery shortage coming. Thanks everyone for your input was very helpful.
Reactions: Dave75
Scoop
Scoop
5,325
20,985
  3. Talon R LV
Lots of shortages are here. Wife went to Meijer and Walmart yesterday. Bread aisle and meat counter below. Thanks, Brandon!
1643740459093
1643740474153
HiFive
HiFive
710
2,961
West Central Fl.
He shut down the pipeline now Europe is dependent on Russia for heating oil so do you think they will really help stop them from invading Ukraine? We are in surious trouble. China is eyeing Twain.
Scoop
Scoop
5,325
20,985
  3. Talon R LV
Shania?
