Talon Axle boot clamp tool
DAJO
182
125
Indiana, Arizona
Anyone know where I can get then Oetiker 1400134 or equivalent that Honda recommends for the large boot clamps inboard and outboard on the axle boots? I have the pinch type tool (ear type) for the small axle clamps but need the large one that is not a pinch (earless) clamps.. Bought one from NAPA that was supposed to work but way too flimsy and the Honda clamps are extremely tight.
21,718
92,869
Thanks guys you have been a big help
I just tried to google "Oetiker 1400134" and came up with nada on image search.
What did you buy from Napa? Link or pn please.
I have used these Knipex pliers with success over the years.
Reactions: DAJO and Ragnar406
DAJO
182
125
Indiana, Arizona
The Knipex are for the ear type clamps, I have those they work on the axle end of the boots but not the large clamps. The large clamps are the earless type that squeeze together and do not crimp like the small clamps. They are really tight and hard to squeeze to the lock position. Finally gave up and put a regular hose clamp on it for now.
21,718
92,869
Ragnar406
Ragnar406
The Great Bald One
4,460
17,085
Bella Vista, AR
Well, Figured out why I came up empty handed looking for your pliers. They are an Oetiker 14100134.
Is this closer to the style you need?
I have a pair of those and they will not work on the larger bands at least for me as I could not get the jaw to open wide enough
I used https://www.amazon.com/dp/B01I3H6UIC/?tag=sxsweb24-20 which is just the front and side jaw version of the ones you posted and they work - on the Pioneer axle bands - it just takes some pressure
Reactions: DAJO
21,718
92,869
The bands he is using are slightly different. I think they are called a low-profile band. It uses a set-up very similar to a cable tie.
I have the exact pair you linked, haven't had any issues with it. But the other band is slightly different.
Reactions: DAJO
DAJO
182
125
Indiana, Arizona
No these clic type clamps are not the same.
The clamps that are on the large end of the boots is
I have the Knipex and tried to use them, could not get enough pressure and moved the band off to the side and out of alignment. Damaged two clamps trying.
DAJO
182
125
Indiana, Arizona
It is a lot more than slightly different one is crimped the other locks into tabs. These 192 style clamps even have waves in them that is temp related on how tight they are.
DAJO
182
125
Indiana, Arizona
Ragnar406
Ragnar406
The Great Bald One
4,460
17,085
Bella Vista, AR
I have spent hours on this and have learned a lot about clamps. Have found that the tool is HIP200 500. The tool would be to large to use without completely removing the axle from the machine.
Are the bands you are trying to close in the pic in that link
3501718E D80C 4E60 8F9A 00891860D6ED
shown above? If so I have used the tool I liked above to close before - i Did have the Axle off the machine and it was a pain..I believe I even put another pair of channel locks on the handles to help close
Reactions: DAJO
DAJO
182
125
Indiana, Arizona
I believe it they are crazy tight, impossible to do on the machine. I guess I will just give up and use the ear type clamps just like they did in a Pioneer thread. P700 - Oetiker clamp tool
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
These work pretty good. Alot easier to use than factory.
Reactions: DAJO
DAJO
182
125
Indiana, Arizona
Yep that is the ones I ordered.
Reactions: GlockMeister
