P1000 armor tech doors vs Honda doors
Buckslayr
141
354
Nd
I have Honda doors on my P 1000-5, they dont seal very well on the bottom, does anybody have armor tech doors that seal good on bottom, in the winter I get snow drifting in the bottom when I.m driving, I have tracks,how do the armor tech seal up? anybody, thanks
Lochsa88
Lochsa88
44
154
i dont have them, but have the honda doors with soft uppers. not that happy with them, but they work. i saw a suggestion to add tailgate weatherstripping to close up gaps, and that has helped a lot. bought off amazon for under 20 bucks as i recall.
211,609
I've been told if you move South the air is thicker and doesn't as bad?
Vikes79
Vikes79
SKOL!
11,955
115,183
South Dakota
  2. Talon X4 LV
If you are using the half doors with soft uppers, use a tailgate seal like I show below. The ones I installed are still working today. They will stop the snow from coming in on the bottoms.
Thread 'Vikes79 Hardwater Honda build'
P1000 - Vikes79 Hardwater Honda build
Lochsa88
Lochsa88
44
154
if that machine was green, id say those were my pics. haha used the same stuff and it's kept the heat in and cold out the past couple winters! and still holding on (wiped dirty plastic doors down with a good degreaser before applying)
NorthernJoe
NorthernJoe
386
1,488
Northern Ontario
If you are running tracks, running boards and mud buster type of fender flares are the only way to keep the snow out. I now have the rear snow flap running all the way back to the ROPS
IMG 8075
Are you running Honda full hard doors or just soft uppers?
NorthernJoe
NorthernJoe
386
1,488
Northern Ontario
where did you get the running boards?i have mud busters on it
I went to a local tin whacker, he made me two lengths .100 aluminum with a 1" x 1" lip I cut and bent the rest. I welded up a 1"x1" frame under the running board and bolted that to the frame. I got the snow flaps from a local rubber supply place. It' 1/4" conveyor belt
