Alternator or battery?
gauspohl4305
gauspohl4305
27
58
Kentucky
So this past weekend while doing some night riding I noticed my lightbar would almost dim down for a second then come back full strength. I am running the dual battery setup with all accessories running off secondary battery. The only additional accessory I'm running off the main battery is Chupacabra led cubes for the headlights. I was running my 40" rough country dual row lightbar, tusk seat heater (only 1 seat), and wicked Pecker Off-road heater. Watching my dual volt meter, I noticed my secondary battery would drop to roughly 10.8 volts and primary would drop to roughly 11 volts as the voltages were fluctuating quit a bit. I turned all the accessories off except the light bar and turned off my brights on the headlights and still noticed the sporadic dimming and voltage all over the place. I also have a torque locker so not sure if that eliminates any additional power required since I'm not utilizing the i-4WD. Would this be a sign of the primary battery starting to fail? Any thoughts, I have checked all wiring and no loose connections that I can find.
DRZRon1
DRZRon1
1,415
4,352
need pics of your rig, you may be asking for someone else , need proof u own this
need pics of isolator\battery\etc....
describe voltage jumping around, when sitting, when bouncing around, etc....
advice to check
-main positive wire rubbing somewhere
-loose\corroded ground
-voltage idling with nothing on, voltage idling with everything on = both batteries
-have both batteries tested
-failing\cracked positive post going to ground
if u have everything off, and both batteries are still doing it, its something common
211,583
Test batteries?
JenElio
JenElio
81,820
712,568
Loxahatchee, florida
Have you tested both batteries? If they're good then maybe check grounds...??
We need a little more info on the machine though..... POIDH!!!😂
