GlockMeister
The Bearded Wonder
Do they cut your turning that much?answers my question if that was the case... was hoping I could buy those and then I could remove the stops...
Hmm...well i guess ill have to see for myself.Supposedly which is why they never got unwrapped.
You can, I’m wary of it and try to not bind them.
@leeI'm not claiming to be any kind of expert but I thought when the CV cup breaks or the cage breaks the likely cause is too much angle.
That picture looks like a cage failure.
If you put down too much torque the axle will break just next to outer CV inner star.
I thought I heard the axles are made to fail first to reduce the cost of fixing it - a new axle being cheaper than a new CV.
But that kind of lets Rhino Axles off the hook (if true).
I know my Dads old Land Rover had a groove machined in to the axle shaft to save the diff.
Apperently teenage age boys speed shifting there Daddys Land Rover where a problem.
(At least it was a problem for me)
I’ve always been of the same mindset... but $200 a complete axle is quite intriguing! I hope they’re not s***!That makes sense, easy to replace a axle, expensive and difficult to replace a diff.
I bet that made your dad ... slightly less angry.
Guy on FB sellin them for 150I’ve always been of the same mindset... but $200 a complete axle is quite intriguing! I hope they’re not s***!
Yeah.. I’m tempted to order a couple but I think I’ll wait until they’re a out for a bit. Let them work out any bugs or defects they might have with the first run batch.Guy on FB sellin them for 150
Figures... guess I'm keeping the spacers tooanswers my question if that was the case... was hoping I could buy those and then I could remove the stops...
