P500 Actual Tire Dimensions: Post Yours
futzin
futzin
4,781
35,076
Kentucky
Figured a thread where we could post our ACTUAL tire dimensions (vs. what's printed on the sidewall) could be helpful for those in the market.
This after seeing a significant difference on a new set of tires on a friends' machine.
I have Kenda Bearclaw HTRs, 27x9x12 and 27x11x12. Height measures 26.5" with 8 lb. psi. (have run them for a year as of now). Width runs true.
I have a set of SunFs on my Foreman. I'll post those up as well when I can.
NTC/TAP Transition Member
11,866
90,400
All I know is that they get lower with use.
BFDE3BBE 3601 46D2 81C6 FAFBE85FED79
JayPo
JayPo
Somewhat Well-Known Member
16,474
150,450
Tennessee
Kenda Bearclaw HTR 26x9x12 and 26x11x12 measure 25.75" on the machine with 6 psi. I think they were just over 26" when I had them at 10 psi.
SP82
SP82
101
356
CA
My 28x10-14 8ply tusk terrabites ran about 27.5 off truck , 27.25 with 12 psi on rig. This is on a 14x7 rim.
Sent from my iPhone using Tapatalk Pro
The Green Goat
The Green Goat
2,411
17,773
Do they rub? How do they ride?
futzin
futzin
4,781
35,076
Kentucky
SunF version of BHs: (one season)
25x8x12, 24.5x8
25x10x12, 25x9.5
Reactions: KyGal83
KyGal83
KyGal83
9,578
93,306
Kentucky
I ordered a set of Big Horn 2.0 's 27x9-12 for the front and 27x11-12 for the rear from KJ Motorsports, then had them mounted on ITP 12 in 5+2 steel wheels from Dennis Kirk. However, they are barely measuring 26 inches in height. This is with 9lbs of pressure in the rears and 11lbs in the front. The only non-stock weight on the machine when I last measured is the following: Honda Roof, windshield, rearview mirror, rear panel, tray, JBL speaker, and power steering. Been bothering me for months as all the research said the BH's ran true to size or larger... disappointed, had I known I probably would have stepped up to 28's.
624DE95C C61B 47BA 9637 E688D7FFCBD3
3F92B3E6 5B69 4895 BF08 229F0D1359A5
  • Wow
Reactions: futzin and Bigtee
195,230
I ordered a set of Big Horn 2.0 's 27x9-12 for the front and 27x11-12 for the rear from KJ Motorsports, then had them mounted on ITP 12 in 5+2 steel wheels from Dennis Kirk. However, they are barely measuring 26 inches in height. This is with 9lbs of pressure in the rears and 11lbs in the front. The only non-stock weight on the machine when I last measured is the following: Honda Roof, windshield, rearview mirror, rear panel, tray, JBL speaker, and power steering. Been bothering me for months as all the research said the BH's ran true to size or larger... disappointed, had I known I probably would have stepped up to 28's.View attachment 275312
Take the weight off of them altogether and measure.
Reactions: KyGal83
195,230
The discussion of actual has been had on the forum many times and some seem to think that it's with the weight of the machine on it. That's going to vary all over the place. What machine it's on, what's been added, PSI, temperature at the time...the only way to do it is with all the weight off of the tire, that'll be consistent and true. Btw, 28" 2.0's measure big, about 28 1/8". 26's measure 26 1/2".
Reactions: KyGal83
