P1000 Acc fuse box connector pigtail
Mhall
12
6
I have a 2020 Honda pioneer 1000 with the added fuse panel. I am looking for the plug to hook up aftermarket accessories. The fuse box connector
IMG 5847
is a two pin plug. Honda dealership said they don’t sell the plug only Honda accessories can plug into to it. I’ve looked at a couple auto parts stores and can’t find the plug. Any info on where to find is appreciated.
Fatsquatch
Fatsquatch
Approved Member
121,188
1,010,463
Hidden
@Hondasxs is this a connector you have sourced?
21,741
93,122
Will this work for you?
Choose a pigtail length.
Reactions: Mhall
Mhall
12
6
The photo is the axillary fuse box installed by the dealer. I am looking for the connector that plugs into the white two hole rectangular connector on the back of the fuse panel. The dealer says that Honda only sells the connector wired to their accessories so I can’t use my own. This circuit is part of the harness that runs into the cab and I would like to use the panel instead of wiring my own switch.
Mhall
12
6
I think the fuse panel has the male plug attached to it. I need the female end. Seems backwards but you can see the pins in the photo. I tried removing the connector but was on the verge of breaking it.
Mhall
12
6
Went and looked again and I think you are all right. This looks like the plug I need! Thanks for all the help. Much appreciated.
Mhall
12
6
One more question if anyone is still reading this. Will the rocker switches on the Club Store snap into the dash panel?
IMG 5848
68,247
That link is what you need.
And our switches will work.
Thanks.
