P500 4wd shifter adjustment
LD500
LD500
0
Arkansas
Just put lockers in the front diff. 4wd want engage. What’s the proper way to adjust linkage
NTC/TAP Transition Member
11,880
90,564
Ensure the spring is in, thinking mine was about halfway of threaded rod. Also make sure the wire for the 4wd indicator light is intact, did you pull the connector off, or did you unscrew the nut when you took it off? The online video shows turning the nut which is not recommended IMO. It pulls off more easily.
Reactions: Mudwing and trigger
21,758
93,308
There was huge thread on the locker install. I believe I uploaded a picture of the service manual page. I'll check my files to see if I saved it.
