2023 Talon R under roof snorkel
hondabob
1,312
5,222
Prescott Valley, AZ
The 1080 snorkel pipe made it a lot easier. I used the 90-degree section of the stock ant farm pipe. The other pipe was from the Pioneer 1000. I get 8,000 to 10,000 miles out of the filter then just replace it. If you ride in heavy dust its ok for about 5,000 miles. It's a PITA to clean and reoil it. The under-roof location gets cleaner air and rain is no problem. The inside of the dirty filter is as clean as new, so it does a great job.
112
117
119
1191
HUCK
HUCK
1,047
2,319
ARIZONA
View attachment 399326View attachment 399327View attachment 399328View attachment 399329View attachment 399331View attachment 399333
You sure do nice work Bob .
Scoop
Scoop
5,382
21,178
  3. Talon R LV
Looks good, Bob. Since you can't put a hard rear windshield back there, are you planning on something custom? Or simply brushing and flossing more often?
  • Haha
Reactions: Remington
hondabob
1,312
5,222
Prescott Valley, AZ
Two of the guys had windshields with the back window. The back window is usually plastic and easy to cut a hole. I cut halfway then finish it from the other side. It may be best to cut the hole 1/4 to 1/2 inch larger due to the window angle.
