P1000 2022 pioneer 1000 SATV A arms
rudyeng
109
554
Florida
Careful the current SATV Front A-Arms do not work on the 2022 Honda Pioneer 1000. You can mount the lowers but not the uppers. You may be able to field engineer a connection by cutting the upper a-arm cross bar but not sure it's worth the risk. You need a good welding/Fabrication shop to modify the uppers. Not worth the risk
Best of luck !
Rudy
NorthernJoe
NorthernJoe
386
1,488
Northern Ontario
Best of luck !
Rudy
Thanks for the heads up!
It will be interesting to see how SATV will fix this
Reactions: JenElio and toddvdh
Best of luck !
Rudy
Ive been spreading this around.
There are several suppliers out there who are advertising A-arms that fit 2016-2022 Pioneer 1000. I dont think that anyone does any research until they get called out.
bumperm
bumperm
1,921
6,820
Gardnerville, NV
I may be wrong here, but in changing the a-arms mounts for the 22, so ostensibly they won't so easily tear the top front frame tab, I would think that aftermarket arms for the '22 would not likely fit the '21 and prior. This is a WAG, of course. Thoughts?
ToddACimer
ToddACimer
Pioneer 1005-2
3,808
16,208
Oshkosh, Wi
Based on my measurements from Takeover they are within 3/8-1/2" from the upper pivot to the ball joint. I thinks there's a good chance they fit for width. The front tab to rear tab is the same. I'd guess at this point they are going to fit with a minor track width change at most.
ToddACimer
ToddACimer
Pioneer 1005-2
3,808
16,208
Oshkosh, Wi
And if @SuperATV pulls through for me, I'll have a set as soon as any 2022 owner
rudyeng
109
554
Florida
The 2022 upper A-Arm has 2 mounting brackets. The upper would need 2 mounting tabs instead of one long bar cross-member (See Pic). It's not SATV's fault. They do not reference the 2022 model. I took the risk. Will probably sell via eBay.
A Arms
116,553
Dont put them on Sleeze Bay or FaceTurd
Put them on here on the For sale/I Wanna thread and give a forum member a chance at them first.
BTW, theres a Thread on this about 2 months ago asking if those would work on a 22’ and @SuperATV
piped in and said no and that they were waiting to get a 22’ so they could fab a set
62,385
I may be interested in the uppers if you want to sell them separate from the lowers. PM me if you want to sell them
SuperATV
SuperATV
1,706
12,515
Madison, IN
www.superatv.com
The current arms will definitely NOT fit the 2022 model. We knew there would be quite a few changes to the frame from Honda's little ads and updates to the 2022. For sure....
- New A-arms
- New Frame Stiffener
- New skid plate
- not sure about tie rods yet...but possible.
- not sure about axles yet, but they should still work...fingers crossed
We JUST got ours in here late last week. The guys already have it stripped down and have been scanning it all day.
NorthernJoe
NorthernJoe
386
1,488
Northern Ontario
- New A-arms
- New skid plate
Any update as to when you will have a front A-arm for the 2022? the website still shows unavailable
ToddACimer
ToddACimer
Pioneer 1005-2
3,808
16,208
Oshkosh, Wi
- New A-arms
- New skid plate
Axles have a larger thread and axle nut.
NorthernJoe
NorthernJoe
386
1,488
Northern Ontario
Not yet, but we already have a design drawn up. Haven't seen the prototypes yet though. I'll check next week for sure.
Thanks
What's your best guess as to when they will be available? I would love to put 30"snow tires on for the winter, but would need the forward A-arms to make that work...
Scoop
Scoop
5,386
21,192
  3. Talon R LV
His original post is gone (deleted?), but I wanted to give a MONSTER sized 'Thank you' to @rudyeng for his generosity. These A-arms are now sitting in the back of my '21 P1K5 Deluxe, so it looks like I need to be ordering the rears from SuperATV soon. He even covered the shipping, which was substantial. All I can say is, muchas gracias!
@rudyeng, I'll be making that donation to St Jude Children's Research Hospital soon, and I am already planning on doing some type of pay-it-forward/similar for someone here on the forums when I have the opportunity.
Aarms
SaltwaterSlick
224
946
Southeast Texas
VERY NICE and Praise the Lord for the opportunity to pay it forward and Give to such a worthy cause!! Don't know @rudyeng, but hat's off to him and you too sir!
