P1000 2020 1000-5 weld crack
Baumer8907
Baumer8907
I have a 1000-5 that has cracked at the weld. I wondered what people had the best luck with. I have thought about just replacing the y pipe. I was wondering if anyone else had taken off and re welded? Or if going to after market was the best? I wouldn’t mind a better tone, however I have outgrew the loud exhaust. Just wondering what would make the sense?
IMG 0372
IMG 0371
IMG 0370
IMG 0373
IMG 0374
JenElio
JenElio
82,064
713,744
Loxahatchee, florida
If you're not thinking of going aftermarket then I'd just weld/repair it and call it a day. The OEM is the quietest exhaust you'll find out there. If you're up for a little heat reduction, removing the CAT helps reduce heat a bit. You'll have the exhaust out already so you'll be halfway there. Quick and easy mod.
Good luck 👍
Baumer8907
Baumer8907
If I’m repairing, I feel like I should replace the y pipe vs welding. Where is the best place to order that from?
Reactions: Backwoods and ChadD
Fatsquatch
Fatsquatch
Approved Member
121,103
1,009,924
Hidden
Ronayers.com
Partzilla
Rockymountainatv
eBay … used or new
Local stealership
Personally if a fella can weld or has a friend that can….I’d weld it. Cost is next to nothing that way. But ultimately it is your decision
WagginTail
WagginTail
1,651
6,059
SC
Just weld it. No need to replace the y pipe. You could split a piece of pipe and put it over the crack and weld it, essentially making the pipe thicker in the area of the crack. That's what I would do if it was mine. Hope that makes sense.
