P1000 1000-6 fender flares/ mud flaps
G
GMCFarms
9
36
Southwest Va
  1. 1000 6 Crew
Looking into some mud/cow poop protection for my 1000-6 and haven’t had much luck with finding pictures. Seems like there’s a bunch of nooks and crannies to pack mud and poop into that may be a pita to clean come spring. I’ve found the mud busters, which look pretty decent maybe? Can’t find a picture of a 1000-6 with them installed and labeled if they are the standard or xl’s. Also found some super atv front inner fender things but they look like they would hold mud behind them and are more of a stick guard. I was hoping to find an inner fender/flare with a rally armour style mud flap. Anyone have any other ideas or pictures that might help me?
Reactions: ChadD
tbaker
371
652
NW. Georgia
I bought a thin sheet of UHMW plastic. I put the mud buster’s on my pioneer 1000-3 and then took a piece of the UHMW plastic and fixed it in front of the rear tires where the mud buster ended it stopped mud from going up underneath the pioneer
Reactions: ChadD
JenElio
JenElio
80,959
708,521
Loxahatchee, florida
I would think it's the same set-up as the P1K-3.....🤷‍♂️
But maybe someone with first hand knowledge might chime in and say otherwise... Good luck
Reactions: ChadD
tbaker
371
652
NW. Georgia
I would say that the mud buster that fits the 1000-3 would fit the 1000-6 because the bed and the front fenders are the same Honda just extended the frame and added the rear set. Mud buster website might be able to confirm that
Reactions: ChadD
Hello_Darkness
Hello_Darkness
611
2,517
Just to the right of nowhere
Mudbusters website list the 3/6 seaters under the same part number.
Reactions: ChadD
Hello_Darkness
Hello_Darkness
611
2,517
Mudbusers like most fender flares are just going to keep stuff from being flung up/out and covering you and passengers
They don't really stop anything from packing into the fender wells.
Reactions: ChadD
Bighat
Bighat
909
3,866
Gallipolis Ohio
I made these out of belting. They work great. No more of this mud build up after I installed them. I farm and used them most of last year and there still on and work good.
Mudflap3
Mudflap2
Mudflap
someguy1313
someguy1313
240
521
SouthEast
dweber23tr
241
768
Minnesota
I also used old gravel stacker conveyor belting on the rear of mine. Def not pretty but it does the job.
20230530 114901
Bighat
Bighat
909
3,866
Gallipolis Ohio
genius. where did you source the belting? i was considering similar up front against the firewall/floorboards to prevent stick intrusion. would take a lot to jam a pointy stick through that.
I got it from a buddy at the power plant but you could just buy the heavy duty big truck mud flaps. I used a piece of aluminum angle to mount to the underside of bed with self tapping screws and then bolt the mud flap on.
