P1000 1000-5 hard door tether
All5Hondas
All5Hondas
Always Honda
29
46
Mountains
Has anyone found a longer door tether for the hard doors? Would like at the least another inch or so, need more room - and yes, it is in the last hole so no further length available. Thanks for any ideas.
20240911 171044 20240911 171033
Reactions: ChadD
Vikes79
Vikes79
SKOL!
11,915
114,895
South Dakota
  2. Talon X4 LV
All5Hondas
All5Hondas
Always Honda
29
46
Mountains
Vikes79, I was thinking that too.......thx. Now to find one :)
Reactions: ChadD
bumperm
bumperm
1,921
6,820
Gardnerville, NV
Or, you could cut that strap off there and just use the end fittings. Replace the strap with double sided "hook and loop" . . . that way you can adjust it however you like. If you find a setting you want and want to make that "permanent", you can put a zip-tie around the middle so the hook and loop can be removed unless you first cut the zip-tie.
All5Hondas
All5Hondas
Always Honda
29
46
Mountains
Interesting, will look at that...thanks!
