P1000 ‘16 1k-5 acts weird at 31-36 mph
N
noisewater
59
188
west michigan
I’ve searched all over this site for my specific problem. 2016 1000-5 deluxe with 8200 miles. When I accelerate slowly or moderately it hesitates at 3500-4000 RPM or more accurately at those RPM when it hits 31-36 MPH. It acts like it wants to grab another gear and it can’t but it’s already in 6th. It does it for a few seconds then catches again and it accelerates just fine after 36 MPH. If I accelerate rapidly - like 4500+ - it works just fine and smooth as ever. It’s only when I moderately accelerate and even when I decelerate. It hits the 31-36 MPH range and “misses” enough where it jolts you forward in your seat. It never comes close to stalling or dying, just seems to “miss” till it gets below 31 MPH or above 36 MPH. Any ideas? I’d rather not have my local jack wagon dealer charge me a grand just to drop it off. I don’t think it’s injectors. Thing runs and idles just like the day I bought it except in that very small window I described. Thanks!
BTW, I did a full oil change/sub change and air filter change and it didn’t help.
Fatsquatch
Fatsquatch
Approved Member
120,467
1,005,910
Hidden
Pretty specific range. Can you get it to mimic this using the paddles?
Fatsquatch
Fatsquatch
Approved Member
120,467
1,005,910
Hidden
Wondering if it can be isolated to an rpm range vs the speed range. I don’t make claims of being much of a mechanic. There are some guys on here that have been into the shift points and fuel maps though that might be able to help better if you can isolate it further though.
HBarlow
HBarlow
1,629
6,048
Daniels, WV
It's hard to read another man's explanation of his problem and diagnose it. If you are accelerating slowly with light throttle until the machine reaches 30 - 35 mp and shifts into 6th gear then pressing the gas to accelerate, that could be a sign of bad or dirty spark plugs misfiring under load.
If that's not correct, I have no idea what is causing your issue. If it was mine I would take it to a dealer and ask them to diagnose the problem and give me an estimate. I'd probably pay the price and let them repair it.
If I wanted to go cheap I would make a couple of inexpensive guesses.
First I would change the spark plugs and carefully inspect the plug wires and the way they are toured to make sure nothing is contacting either.
Second, I would run a tank or two full of gas with a bottle of Chevron Techron additive added to each tank full. Techron is an excellent fuel additive for injector cleaning. It works.
If those two wild guesses don't help the only thing I know to do is take it to a dealer and pay the one hour labor charge most dealers charge to diagnose.
116,510
One question, its a 16’ did u get the clutch campaign update done?
Also, have you cahnged the injector wiring harness that plagues
The the early P1 models?
Thats “injector harness” not the injector itself.
N
noisewater
59
188
west michigan
Just a moderate steady consistent acceleration. I don’t “step on it” after or approaching the problem speed. If I accelerate more aggressively from 0 mph then there is no problem at all.
Reactions: ChadD and TxDoc
N
noisewater
59
188
west michigan
Clutch was done in 17 (I think that was the year) on the recall.
Haven’t heard of the injector wiring harness issues before. This thing has been problem free for 6+ years and 8200 miles so I’ve never had to spend much time here. Is there a link to the harness?
TripleB
TripleB
19,338
171,399
Caryville, Tennessee
N
noisewater
59
188
west michigan
Are you in low range if so thats all you have.
High range
Well I put a quart of sea foam in it and did about a 30 mile drive. Let it idle for about 5 mins before taking off. Acted up once in the first half mile and then never again in the next 30. You gotta be kidding me. Is it possible it worked that quickly? This thing has done it without fail the past 500ish miles. Hot or cold engine. Didn’t matter. I did everything I could to make it do it again on this ride and nothing. Manual mode. Auto mode. Sport mode. No issues after the first half mile. I don’t hardly dare believe it.
Fatsquatch
Fatsquatch
Approved Member
120,467
1,005,910
Hidden
High range
Sometimes being lucky is better than being good!
Nomojic
HBarlow
HBarlow
1,629
6,048
Daniels, WV
High range
Congratulations! Sometimes the simplest, most basic solutions to a problem produce results.
bumperm
bumperm
1,921
6,820
Gardnerville, NV
Yup like i tell my young techs at work. Work smarter not harder. Do the easy stuff first, 9 times out 10 youll find it there.
Agree! Going through Navy Electronics Technician "A" School, back in '63/'64. one of the first rules of troubleshooting was and remains, "Check the Easy Stuff First". On board ship, this was quickly followed by the "Floatation Test". :)
