P700 Won’t crank
U
Usi
7
New zealand
Hi all so my 2014 P700 will try to crank and will crank fine if I have the throttle wide open but if I let off it will bind and load up. It turns over fine has good compression according to the manual. I have checked the timing and all lines up with the book. Has had a new cam and crank sensor couple months ago. It started to get worse over the span of a few weeks until now it will not start at all. Any one had this before ?
