P500 Service price
Dan Lawrie
Dan Lawrie
Las Vegas, NV
It's time for my p520 to have its 1800 mile check and lube. I was quoted $932.00 for this service by the dealer. My acura mdx doesn't cost $200 for this service. How is this possible?
  • Wow
Reactions: SILVER_ALERT
194,506
They're gouging IMO. There are no grease zerks. Change the oil and air filter. I'd change the differential gear oil while you're at it, 75/140 especially for your climate. No need to check valve clearance unless it's running bad. Mine is a '15 and I've never checked the valve clearance.
Dan Lawrie
Dan Lawrie
Las Vegas, NV
I just ordered the filters, oil, lube, spark plug and gap gauge on amazon for $75.00. I saved $850 doing it myself. I asked a second dealer and he wants 2k up front for the next 4 services. Plus pickup.
194,506
There you go. Mine hasn't seen a dealer since the day I bought it. Way cheaper and you know it'll be done right. 👍
Hello_Darkness
Hello_Darkness
651
2,648
Just to the right of nowhere
Every screw type valve adjustment engine I've serviced has needed the valves adjusted at the initial 100 miles serviced and usually every other one after.
Just because it's running doesn't mean it's right .
Reactions: trigger
211,598
What about valve adjustment on a new head on a 16 P1 w/ 4,500 miles? I believe they have shims?
DRZRon1
DRZRon1
1,415
4,352
PA
because they can
It’s not apples to apples - Acura ain’t checking valves, changing diff fluids etc.
while I agree that is a lot of Benjamin’s - it’s where this crazy world is at currently
Dan Lawrie
Dan Lawrie
Las Vegas, NV
Your right my acura mdx cost 80k and oil change, tire rotation, lube and everything else they do is about 100 dollars, plus they give me a loaner car free for the day. The sxs dealer is a rip off.
Hello_Darkness
Hello_Darkness
651
2,648
The Intakes are shims, exhaust are still screw adjusters.
Every 1000 engine I've inspected at the 1st service has needed exhaust adjustment. I think the factory may not be getting them as tight as they need to tbh.
211,598
Thanks, I wish Fairfield was close.
