I
When I'm going slow and not applying much gas pedal I hear a squeaking from my rear brakes. I jacked up the rear end and spin the tires in neutral with motor off, and the brakes are slightly rubbing on the rotor. I doesn't seem to impede the rotation of the tires. Otherwise, the brakes perform normally.
Is there some sort of contact adjustment you can make or is this normal?
Thanks.
Thanks.
