P500 P500 Ignition Switch Connector
N
nzkiwi
14
NZ
Can anyone provide details of the P500's ignition switch connector parts (connector body, pins)? And a source for these component?
I want to replace the stock 3-position ignition switch (OFF-ON-START) with a 4-position ignition switch (Cole Hersee, ACC-OFF-ON-START) to power accessories from an auxiliary battery while the engine is not running. Rather than modifying the factory harness, I prefer to fabricate a separate add-on harness for the new ignition switch and associated relays (the Cole Hersee switch does not have the same current rating as the stock Honda switch) that will plug into the ignition switch connector on the harness.
