Only have had time to put 30 miles of mixed driving so far, but I have made note of shifting points according to rpm's. For me, in high range while driving it easy, it upshifts right about 3500rpm's. In low range it's almost 4500rpm's before it upshifts. Does that sound about right?
Also, when changing from turf, to 2wd, or 4wd, or 4wd diff lock, I have to drive around a bit before it engages. Is this normal? I'm not really concerned with 2wd to turf as much as I am when trying to get it in 4wd diff lock. If I'm in a bad place I want to lock in the 4wd diff, then ease out of it with all four tires pulling. That's not an option if I have to drive it around for anywhere from 20 feet to 200 feet before it finally engages. I'm thinking when I select 4wd diff lock it should be there now, or shortly after I give it some throttle. How does your rigs react to drive modes changes?
Don't get me wrong, I love this rig, but if I'm in a bad spot and need to crawl out in low range and 4wd lock, driving around a while and waiting for it to engage is a piss poor design if that's normal for the transfer.
