![Gb63](/data/avatars/m/12/12374.jpg?1692204428)
Hey all....Has anybody had to change front calipers or rebuild them. One of mine is sticking on occasion. Just trying to find the best out. Honda wants like $300 a piece for theirs....
My 2017 right front was sticking at 3453 miles/430 hrs.Got a full set of Niche for about $47 at Walmart.com.Put 1276 miles on them so far.Problem was slide pins were mostly dry. I removed small nicks with Scotch-brite,put some brake lube on pins and the rest is historyHey all....Has anybody had to change front calipers or rebuild them. One of mine is sticking on occasion. Just trying to find the best out. Honda wants like $300 a piece for theirs....
I pulled the calipers and greased the pins and slide contact areas. Also worked the piston in and out a few times. No sticking as of now...we'll see how long it last....My 2017 right front was sticking at 3453 miles/430 hrs.Got a full set of Niche for about $47 at Walmart.com.Put 1276 miles on them so far.Problem was slide pins were mostly dry. I removed small nicks with Scotch-brite,put some brake lube on pins and the rest is history
Well, caliper started sticking again. I removed it and tried to work it free with c clamp and air...seized up. Replaced with new one$$$$.....all is good now.I pulled the calipers and greased the pins and slide contact areas. Also worked the piston in and out a few times. No sticking as of now...we'll see how long it last....
Mine was sticking and I just rebuilt it.Well, caliper started sticking again. I removed it and tried to work it free with c clamp and air...seized up. Replaced with new one$$$$.....all is good now.
Amazon has them for under $100Anybody have any rebuild kit part numbers?
go on Ron ayers, partzilla, motorsport - etc. - search under the oem parts if you choose to go down that road - I think a set of seals is $10 and if you change both pins, maybe another $15, imo - id get it apart and see what you need - probably just a good cleaning and a new set of seals is all that is needed - ive not seen many bad pistons but anything is possibleAnybody have any rebuild kit part numbers?
