P1000 Denali Pro
Stumper
Bandana, NC
I had tagged onto an old thread hoping to get help on a problem I am having with a new Denali Pro for my 2022 P31000. A couple others had mentioned having the same issue so I thought I would post this separate thread with the fix.
The problem is not being able to adjust the plow feet to be perpendicular to the ground. I had tried everything starting with using the shortest side of the supplied blade stop blocks to completely removing any stop period always had the forward tilt to the feet. With no stop at all the blade just hits the frame and still doesn’t allow the feet to sit level on the ground.
The fix from Motoalliance is to purchase a set of adaptors as if the machine has a lift kit in it…. for $80. I’m sure that will resolve the problem and plan to order them in a few minutes, but I don’t know why the adaptor should be needed. My machine is a stock Deluxe model with stock wheels and tires. It is not lifted at all. Anyway, for those of you that may be having the same problem the fix is to lower the mounting point to the machine.
