Before I dive in!!
Jason W
Jason W
The Ginger Cracker
978
8,436
Western NC mtns
Few questions before I start building my new talon...
I have the @Hondasxs harness for tap in key on and blue plug, which is best for winch key on, and which one for usb, and voltmeter.
how to access the blue plug??
How to access the seat belt lock out plug?
Im going to wire gmrs straight to battery.
I bought the @SuperATV rear storage box, it's 3 inches too long, or am I missing something.
Any wierd things I need to know before I dive in , lessons you've learned, on winch skids whatever.
Thanks in advance I'm a Marine, I need things written in crayon sometimes, thanks yall
Jason W
Jason W
The Ginger Cracker
978
8,436
Western NC mtns
@SuperATV I misunderstood on box
Vondy
Vondy
1,509
10,009
Houston,OH
  1. Talon X4
I used the blue plug to key on the winch. hondasxs has a pigtail that plugs in behind the cig outlet that I used for key on for everything else that’s attached to a switchpros panel.
When you’re wiring all your stuff up it’s easiest to just take the panel between hood and dash off. Easy access to blue plug and access to mount things and run wires.
Good idea on wiring the gmrs to be on all time. Drives me crazy when people wire them thru key on and then can’t hear when they are sitting there with machine off. I wired mine on button on switchpros so that I could turn it on and off that way and it would stay on.
No idea on the superatv box, I would recommend a packout mount and packouts.
60,466
Before you start wiring anything up, I'd absolutely recommend the switchpro or the auxbeam switch panel. It makes wiring everything up so much easier and allows for easy upgrades later on down the road. Everything else is pretty much personal preference.
