2024 P 500
Garlicfarmer
Garlicfarmer
66
339
53
Oregon
  1. Looking to buy
Just wondering.
Has anyone heard if Honda is coming out with a P 500 for 2024 ???
I have searched with no luck. I have a friend interested in buying one this fall.
SILVER_ALERT
SILVER_ALERT
HONDA SXS Club Flounder
3,079
20,913
Route 66 Oklahoma
All that they are showing on their (USA) website right now is the 2024 Talon, Pioneer 1000, 1000-5, 1000-6, 700, and 700-4. No mention of the 2024 Pioneer 500 or 520. I'm sure the 520 will be back, but I would think that the 500 might not make it, since they are so similar in specs and only about $1k difference in price.
2023 Honda Pioneer 500 Specifications​
March 1, 2023
ENGINEPioneer 520Pioneer 500
2023 Honda Pioneer 520 / Pioneer 500
SPECIFICATIONS
Type518cc liquid-cooled longitudinally mounted single-cylinder four-stroke475cc liquid-cooled longitudinally mounted single-cylinder four-stroke
Valve TrainOverhead valve pushrod & rocker arm
Bore x Stroke96.0mm x 71.5mm92.0mm x 71.5mm
Compression Ratio9.5:1
InductionFuel injection (PGM-FI), 36mm throttle body
IgnitionFull transistorized
StarterElectric
DrivelineDirect front and rear driveshafts
TransmissionAutomatic ESP 5 speed + reverse
ClutchAutomatic
SUSPENSION
FrontIndependent double wishbone; 5.8 in. travel
RearIndependent double wishbone; 5.9 in. travel
BRAKES
Front2 hydraulic calipers w/ 200mm discs
Rear1 hydraulic caliper w/ single 170mm disc
TIRES
Front24 x 8-12
Rear24 x 10-12
MEASUREMENTS
Length105.0 in.102.6 in.
Width50.0 in.
Height71.2 in.
Seat Height27.7 in.
Ground Clearance 8.5 in.
Wheelbase73.0 in.
Turning Radius12.8 ft.
Towing Capacity1,000 lbs.
Payload Capacity450 lbs.
Fuel Capacity4.1 gal., (1.1 gal. reserve)
Curb Weight*1,058 lbs. (1,060 lbs. CA)1,027 lbs. (1,030 lbs. CA)
OTHER
ColorsAvenger Red; Black Forest Green; Sandstone Beige; Krypton GreenAvenger Red; Black Forest Green
